If for instance you're after internal "latent loads" (see here), you can request an annual tally :
... and look up the results (in J) in the ESO file. You can do the same for infiltration latent loads, as well as sensible (and/or total) loads, and so on.
I think generating a concise table (in OpenStudio) from selected latent + sensible load components would require an EnergyPlus measure or customizing the OpenStudio Results Measure.
