I don't know what you have defined in the model. The EnergyPlus engine has hundreds of outputs that can be requested and I don't remember all of them by heart. If possible, please provide the dsb or idf file so I can provide more specific guidance.
You can view all available output variables either in the .rdd file or through the EMS scripting add output interface. The step-by-step instructions are described in this knowledgebase article. https://support.designbuilder.co.uk/support/solutions/articles/103000181523-requesting-additional-outputs-for-your-simulation
Depending on the model you use, you may have access to the following outputs:
Zone,Average,EMPD Surface Inside Face Water Vapor Density [kg/m3] Zone,Average,EMPD Surface Inside Face Humidity Ratio [kgWater/kgDryAir] Zone,Average,EMPD Surface Inside Face Relative Humidity [%]
Zone,Average,HAMT Surface Temperature Cell N [C] Zone,Average,HAMT Surface Water Content Cell N [kg/kg] Zone,Average,HAMT Surface Relative Humidity Cell N [%] Zone,Average,HAMT Surface Average Water Content Ratio [kg/kg] Zone,Average,HAMT Surface Inside Face Temperature [C] Zone,Average,HAMT Surface Inside Face Relative Humidity [%] Zone,Average,HAMT Surface Inside Face Vapor Pressure [Pa] Zone,Average,HAMT Surface Outside Face Temperature [C] Zone,Average,HAMT Surface Outside Face Relative Humidity [%] Zone,Average,HAMT Surface Inside Face Relative Humidity [%]
Source: https://bigladdersoftware.com/epx/docs/9-4/input-output-reference/group-surface-construction-elements.html
Zone,Average,EMPD Surface Inside Face Relative Humidity Source: https://bigladdersoftware.com/epx/docs/9-4/input-output-reference/group-surface-construction-elements.html
| 4 | No.4 Revision |
If possible, please provide they depend on the dsb or idf file so I can provide more specific guidance.model you have defined.
