If I understand correctly, your problem is with this EMS Sensor:
RCan, !- Name
THERMAL ZONE 1, !- Output:Variable or Output:Meter Index Key Name
Zone Windows Total Transmitted Solar Radiation Rate; !- Output:Variable or Output:Meter Name
The solar enclosure is probably the name of the Space. Try using the space name 101 smartfarm and see if that works.
RCan, !- Name
This looks like the same issue as NREL/EnergyPlus#10552 - "Zone Exterior Windows ..." output variables confusingly take a Space name
