That IDF file comes with a freshly dowloaded EnergyPlus. Look under "/ExampleFiles", once installed. You can also find that IDF (and many others) in EnergyPlus' GitHub repo under testfiles.
EnergyPlus is indeed distributed with every OpenStudio or OpenStudio Application download, yet without the EnergyPlus test/examples files.
That IDF file comes with a freshly dowloaded downloaded EnergyPlus. Look under "/ExampleFiles", once installed. You can also find that IDF (and many others) in EnergyPlus' GitHub repo under testfiles.
