1 | initial version |
The [Commercial Buildings Energy Consumption Survey](http://www.eia.gov/consumption/commercial/data/2012/_ is probably your best bet. Take a look at the spreadsheets under "End-use equipment".
2 | No.2 Revision |
The [Commercial Commercial Buildings Energy Consumption Survey](http://www.eia.gov/consumption/commercial/data/2012/_ Survey is probably your best bet. Take a look at the spreadsheets under "End-use equipment".
3 | No.3 Revision |
The Commercial Buildings Energy Consumption Survey is probably your best bet. Take a look at the spreadsheets under "End-use equipment".equipment". There you will find a breakdown of how often each equipment type is used in different types of buildings. For example:
