Alright, seems like we figured out the root cause of the above errors: it turns out that if you copy the windows (sub-surfaces) into other levels, such errors arise. If at all, one wants to copy/duplicate levels to save time. Following workflow shall be followed (based on my experience):
Few tips: Keep saving your .osm model at each step and consistently check the warning/error log (the orange triangle with exclamation mark), to make sure its going well or not - that way you can always go to the previously saved .osm file, in case the current one comes up with errors.
I would like to extend my gratitude and thanks to Denis and Jamie, whose answers (above) undoubtedly were helpful and a guiding source. Much appreciated guys!
PS: Anyone, please upvote if you find this helpful. Cheers!
