I am currently trying to do the exact same thing, and am encountering the exact same issue. If you have any insight into this, happy to discuss.
I am currently trying to do the exact same thing, used the following code to generate the defrost schedule for the air chiller object. For refrigerated warehouse a more frequent defrost schedule than typical may be required.
note: generative A.I. was used to inform this code.
#create a defrost_schedule using ScheduleRuleset
defrost_schedule = OpenStudio::Model::ScheduleRuleset.new(model)
defrost_schedule.setName("Frequent Defrost Schedule")
default_day = defrost_schedule.defaultDaySchedule
default_day.setName("Default Day Schedule")
# Define hourly values for the default day with six defrost cycles per day
# Each cycle lasts for 30 minutes and am encountering the exact same issue. If you have any insight into this, happy to discuss.occurs every 4 hours
default_day.addValue(OpenStudio::Time.new(0, 0, 0, 0), 0.0) # Start with no defrost
default_day.addValue(OpenStudio::Time.new(0, 0, 30, 0), 1.0) # Defrost from 12:00 AM to 12:30 AM
default_day.addValue(OpenStudio::Time.new(0, 4, 0, 0), 0.0) # No defrost from 12:30 AM to 4:00 AM
default_day.addValue(OpenStudio::Time.new(0, 4, 30, 0), 1.0) # Defrost from 4:00 AM to 4:30 AM
default_day.addValue(OpenStudio::Time.new(0, 8, 0, 0), 0.0) # No defrost from 4:30 AM to 8:00 AM
default_day.addValue(OpenStudio::Time.new(0, 8, 30, 0), 1.0) # Defrost from 8:00 AM to 8:30 AM
default_day.addValue(OpenStudio::Time.new(0, 12, 0, 0), 0.0) # No defrost from 8:30 AM to 12:00 PM
default_day.addValue(OpenStudio::Time.new(0, 12, 30, 0), 1.0) # Defrost from 12:00 PM to 12:30 PM
default_day.addValue(OpenStudio::Time.new(0, 16, 0, 0), 0.0) # No defrost from 12:30 PM to 4:00 PM
default_day.addValue(OpenStudio::Time.new(0, 16, 30, 0), 1.0) # Defrost from 4:00 PM to 4:30 PM
default_day.addValue(OpenStudio::Time.new(0, 20, 0, 0), 0.0) # No defrost from 4:30 PM to 8:00 PM
default_day.addValue(OpenStudio::Time.new(0, 20, 30, 0), 1.0) # Defrost from 8:00 PM to 8:30 PM
default_day.addValue(OpenStudio::Time.new(0, 24, 0, 0), 0.0) # No defrost from 8:30 PM to 12:00 AM
I used the following code to generate the defrost schedule for the air chiller object. For refrigerated warehouse a more frequent defrost schedule than typical may be required.
# Define hourly values for the default day with six defrost cycles per day # Each cycle lasts for 30 minutes and occurs every 4 hours default_day.addValue(OpenStudio::Time.new(0, 0, 0, 0), 0.0) # Start with no defrost default_day.addValue(OpenStudio::Time.new(0, 0, 30, 0), 1.0) # Defrost from 12:00 AM to 12:30 AM default_day.addValue(OpenStudio::Time.new(0, 4, 0, 0), 0.0) # No defrost from 12:30 AM to 4:00 AM default_day.addValue(OpenStudio::Time.new(0, 4, 30, 0), 1.0) # Defrost from 4:00 AM to 4:30 AM default_day.addValue(OpenStudio::Time.new(0, 8, 0, 0), 0.0) # No defrost from 4:30 AM to 8:00 AM default_day.addValue(OpenStudio::Time.new(0, 8, 30, 0), 1.0) # Defrost from 8:00 AM to 8:30 AM default_day.addValue(OpenStudio::Time.new(0, 12, 0, 0), 0.0) # No defrost from 8:30 AM to 12:00 PM default_day.addValue(OpenStudio::Time.new(0, 12, 30, 0), 1.0) # Defrost from 12:00 PM to 12:30 PM default_day.addValue(OpenStudio::Time.new(0, 16, 0, 0), 0.0) # No defrost from 12:30 PM to 4:00 PM default_day.addValue(OpenStudio::Time.new(0, 16, 30, 0), 1.0) # Defrost from 4:00 PM to 4:30 PM default_day.addValue(OpenStudio::Time.new(0, 20, 0, 0), 0.0) # No defrost from 4:30 PM to 8:00 PM default_day.addValue(OpenStudio::Time.new(0, 20, 30, 0), 1.0) # Defrost from 8:00 PM to 8:30 PM default_day.addValue(OpenStudio::Time.new(0, 24, 0, 0), 0.0) # No defrost from 8:30 PM to 12:00 AM
| 4 | No.4 Revision |
#create # Create a defrost_schedule new defrost schedule using ScheduleRuleset
ScheduleCompact
defrost_schedule.setName("Frequent OpenStudio::Model::ScheduleCompact.new(model)
defrost_schedule.setName("RefrigeratedWarehouse.idf Defrost Schedule")
default_day
# Set schedule type limits
discrete_type_limits = defrost_schedule.defaultDaySchedule
OpenStudio::Model::ScheduleTypeLimits.new(model)
discrete_type_limits.setName("ON/OFF")
discrete_type_limits.setLowerLimitValue(0)
discrete_type_limits.setUpperLimitValue(1)
discrete_type_limits.setNumericType("Discrete")
defrost_type_limits = discrete_type_limits
defrost_schedule.setScheduleTypeLimits(defrost_type_limits)
# Define the schedule values using Schedule:Compact format
# Defrost schedule matches AirChillerDefrostSched1 in RefrigeratedWarehouse.idf
defrost_schedule.addValue("Through: 12/31")
defrost_schedule.addValue("For: AllDays")
defrost_schedule.addValue("Until: 05:00", 0)
defrost_schedule.addValue("Until: 05:20", 1)
defrost_schedule.addValue("Until: 22:00", 0)
defrost_schedule.addValue("Until: 22:40", 1)
defrost_schedule.addValue("Until: 24:00", 0)
# Create an air chiller using defrost_schedule above
air_chiller = OpenStudio::Model::RefrigerationAirChiller.new(model, defrost_schedule)
