This is the error message:
** Severe ** HVACTemplate:* objects found. These objects are not supported directly by EnergyPlus.
** ~~~ ** You must run the ExpandObjects program on this input.
I don't know how you are running EnergyPlus, but e.g. you can run the ExpandObjects project using the -x argument when running from the commandline:
energyplus.exe -x file.idf ...
