One option would be to just apply the heating rate as an internal heat gain. Then, a trick you can use for EMS controls is to set the value of the internal gain object (or similar) to 1, and then you use the EMS to control its schedule. So if, say, you want 100W you can have the EMS set the schedule value to 100 as 100*1 = 100.
