The cooling coil appears to be a CoilCoolingWater. As such, it is a WaterToAirComponent. And as such, it inherits the airInletModelObject(), airOutletModelObject(), waterInletModelObject() and waterOutletModelObject() methods. I do not kow whether these always return a node, but here is a Pyhton snippet to see what gives.
import openstudio
cooling_coil_name = "CHWC-1"
cooling_coil = model.getCoilCoolingWaterByName(cooling_coil_name)
if cooling_coil.is_initialized():
cooling_coil = cooling_coil.get()
cooling_coil_node = cooling_coil.airOutletModelObject()
if cooling_coil_node.is_initialized():
cooling_coil_node = cooling_coil_node.get()
if isinstance(cooling_coil_node,openstudio.openstudiomodelhvac.Node):
print("Congratulations, this is a Node: ",cooling_coil_node)
else:
cooling_coil_node = cooling_coil_node.to_Node()
print("Congratulations perhaps, this may be a Node: ",cooling_coil_node)
