I don't think you can control the scale in those plots, unfortunately.
You can plot the differences between two plots on a third plot that has one scale. If you select two variables, right click and select Flood variable1 - variable 2, you can get the difference plot. But whether or not your clients can understand such a plot is a question though, so it is only a marginal substitute for a control that RV should have but doesn't.
