To help around this bug one can do the following:
(a) if you change the Control Variable setting back to Temperature, the setpoint manager symbol re-appears,
and you are able to delete the SPM, if necessary.
(b) if you switch between the displays of HVAC loops and return to the loop with the missing SPM symbol, at least the visual handle for deleting the setpoint manager becomes visible.
In this way it is possible to do HVAC loop editing despite the bug.
If the visual handle for deleting the SPM is still missing, switch between the displays of HVAC loops and
return to the original loop: now also the handle for deleting the SPM becomes visible, and you are able to delete can delete
the SPM, setpoint manager, if necessary.
(b) if you switch between reset the displays of HVAC loops and return Control Variable to Maximum Temperature (or other options), the loop with the missing SPM symbol,
at least will again disappear, but the visual handle for deleting the setpoint manager becomes SPM may still remain visible.
