The key piece of information in that file is EnergyPlus Terminated with a Fatal Error. This means the EnergyPlus simulation failed and you will need to go to your "run" folder and open the eplusout.err file (with your favorite text editor) to determine why.
I typically start by searching for the term "severe" in that file since it can be fairly long. That should get you on the path to the problem.
