Nice! thx for that rich script. It worked for me on Linux with eplus v24.1, BUT I had to add the number of Vertices manually from "" to "4" for every surface:
BuildingSurface:Detailed,
Surface 1, !- Name
Floor, !- Surface Type
ExtSlabCarpet 4in ClimateZone 1-8, !- Construction Name
Thermal Zone 1, !- Zone Name
Thermal Zone 1 Space, !- Space Name
Ground, !- Outside Boundary Condition
, !- Outside Boundary Condition Object
NoSun, !- Sun Exposure
NoWind, !- Wind Exposure
, !- View Factor to Ground
4, !- Number of Vertices
0.966639036161356, -0.951827216061757, 0, !- X,Y,Z Vertex 1 {m}
2.28789326978621, -6.29076786474157, 0, !- X,Y,Z Vertex 2 {m}
-6.25441176810156, -8.40477463854147, 0, !- X,Y,Z Vertex 3 {m}
-7.57566600172645, -3.06583398986163, 0; !- X,Y,Z Vertex 4 {m}
Maybe you could add for such cases something like this:
if "!- Number of Vertices" is "":
contains_vertex = df.apply(lambda column: column.str.contains('Vertex', na=False)).any(axis=1)
number_of_rows = contains_vertex.sum()
or
for line in file:
if 'Vertex' in line:
count += 1
