The gbXML appears to have a date with the year set as 1, which doesn't make sense since it should be 2024 or similar. You can manually edit the file in a text editor to fix the date.
But you should also tell Archicad to fix their software. Apparently their software sometimes, or used to, set the year as 0, which also causes problems.
