Here is some example code on how to do this.
import eppy
from io import StringIO
txt = """
Version, 23.2;
People,
189.1-2009 - Office - Corridor - CZ4-8 People, !- Name
189.1-2009 - Office - Corridor - CZ4-8, !- Zone or ZoneList or Space or SpaceList Name
Office Work Occ, !- Number of People Schedule Name
People/Area, !- Number of People Calculation Method
0.0107639104167097, !- People per Floor Area
, !- Floor Area per Person
0.3, !- Fraction Radiant
, !- Sensible Heat Fraction
Office Activity; !- Activity Level Schedule Name"""
idf = eppy.openidf(StringIO(txt))
peoples = idf.idfobjects["people"]
people = peoples[0]
print(people)
## OUTPUT
People,
# to see all the field names of people
fieldnames = people.fieldnames
for fieldname in fieldnames:
print(fieldname)
## OUTPUT
key
Name
Zone_or_ZoneList_or_Space_or_SpaceList_Name
Number_of_People_Schedule_Name
Number_of_People_Calculation_Method
Number_of_People
People_per_Floor_Area
Floor_Area_per_Person
Fraction_Radiant
Sensible_Heat_Fraction
Activity_Level_Schedule_Name
Carbon_Dioxide_Generation_Rate
Enable_ASHRAE_55_Comfort_Warnings
Mean_Radiant_Temperature_Calculation_Type
Surface_NameAngle_Factor_List_Name
Work_Efficiency_Schedule_Name
Clothing_Insulation_Calculation_Method
Clothing_Insulation_Calculation_Method_Schedule_Name
Clothing_Insulation_Schedule_Name
Air_Velocity_Schedule_Name
Thermal_Comfort_Model_1_Type
Thermal_Comfort_Model_2_Type
Thermal_Comfort_Model_3_Type
Thermal_Comfort_Model_4_Type
Thermal_Comfort_Model_5_Type
Thermal_Comfort_Model_6_Type
Thermal_Comfort_Model_7_Type
Ankle_Level_Air_Velocity_Schedule_Name
Cold_Stress_Temperature_Threshold
Heat_Stress_Temperature_Threshold
# add a field name, say 'Air_Velocity_Schedule_Name'
people.Air_Velocity_Schedule_Name = "air vel. schedule"
print(people)
## OUTPUT
People,
Office Activity, !- Activity Level Schedule Name
, !- Carbon Dioxide Generation Rate
, !- Enable ASHRAE 55 Comfort Warnings
, !- Mean Radiant Temperature Calculation Type
, !- Surface NameAngle Factor List Name
, !- Work Efficiency Schedule Name
, !- Clothing Insulation Calculation Method
, !- Clothing Insulation Calculation Method Schedule Name
, !- Clothing Insulation Schedule Name
air vel. schedule; !- Air Velocity Schedule Name
Short answer: eppy CAN add fields into an existing object
import eppy
txt = """
Version, 23.2;
People,
people = peoples[0]
print(people)
## OUTPUT
People,
print(fieldname)
## OUTPUT
key
Name
Number_of_People
Fraction_Radiant
print(people)
## OUTPUT
People,
