It may be that the Sizing:Zone Zone Cooling Design Supply Air Humidity Ratio is higher than what is calculated for the coil inlet air humidity ratio (i.e., mixing return air and outdoor air)? You could try lowering the Sizing:Zone cooling supply air hum rat. Also try lowering the same variable in the Coil:Cooling:Water object if the Sizing:Zone change does not work. It looks like this warning needs more information so the user can figure out what is wrong (e.g., inlet air temp, inlet air hum rat, outlet air temp, outlet air hum rat, etc).
