If you used the QtIFW (binary) installers: .exe on windows, .dmg on mac, .run on linux, then you have a maintenancetool in the install folder: use that to uninstall it completely including shortcuts/symlinks.
On Windows you can also find it in the Control Panel > Uninstall a Program
If you installed it via the tar.gz/.zip, just delete the folder.
