Set the actuator value to 'Null'. From the Application Guide:
Actuators override things inside EnergyPlus whenever the actuator’s Erl variable is set to a value other than “Null.” Null is a special built-in variable used to deactivate an actuator. Once an actuator starts overriding, it will continue to do so until the actuator’s Erl variable is set to Null. You should set the actuators to Null whenever you want the EMS to revert to normal operation.
![]() | 2 | No.2 Revision |
Set the actuator value to 'Null'. From the EMS Application Guide:
