It looks like the residential_quota_downselect doesn't work by running workflow/run_analysis.rb. But it works by running using the buildstockbatch environment. I would suggest using the buildstockbatch environment. https://github.com/NREL/buildstockbatch Also suggest set resample as true if it still doesn't work.
