You can use WaterHeater:HeatPump:PumpedCondenser or WaterHeater:HeatPump:WrappedCondenser to model heat pump water heaters. There is no input field for the refrigerant type. You can customise performance curves of the DX coil in the water heater.
Please refer to ExampleFiles WaterHeaterHeatPumpStratifiedTank.idf, WaterHeaterHeatPumpWrappedCondenser.idf, HeatPumpWaterHeater.idf and HeatPumpWaterHeaterStratified.idf.
