Comments in this 5-year old post suggest one cannot have both plugins coexisting within SketchUp, at least not enabled simultaneously. Not a Euclid user; this may have changed since then ...
As OpenStudio v2.9.1 won't read/write EnergyPlus v22.1, are you contemplating a unidirectional workflow (?):
OpenStudio v2.9.1 plugin >> v9.2.0 IDF >> Euclid >> v22.1 IDF
As OpenStudio v2.9.1 won't read/write EnergyPlus v22.1, are you contemplating a unidirectional workflow (?):workflow?
