1 | initial version |
OpenStudio has caught a self-intersecting face (or polygon) here. Maybe post the whole error output, which I believe should list the problem face vertices in sequence (like this). Should be easy to diagnose.
2 | No.2 Revision |
OpenStudio has caught a self-intersecting face (or polygon) polygon here. (see line 950). Maybe post the whole error output, which output (which I believe should list the problem face culprit polygon vertices in sequence (like sequence ... like this). Should be easy Better yet, provide a link to diagnose.the generated .osm file. The issue is likely due to the sequence of vertices of some surfaces (e.g. "Face 245", "Surface 35"), or those of their adjacent surfaces.
