I do my best to keep this service running as the app is using legacy code. I am unsure how much longer we are going to support modelmaker.nrel.gov or the example file generator. The best approach for the future is to use OpenStudio and use either the SketchUp plug-ig or scripts to generate models dynamically. You can then use PAT to perturb the model using measures from the Building Component Library.
I do my best to keep this service running as the app is using legacy code. I am unsure how much longer we are going to support modelmaker.nrel.gov or the example file generator. generator. The best approach for the future is to use OpenStudio and use either the SketchUp plug-ig or scripts to generate models dynamically. You can then use PAT to perturb the model using measures from the Building Component Library.
I do my best to keep this service running as the app is using legacy code. I am unsure how much longer we are going to support modelmaker.nrel.gov or the example file generator. The best approach for the future is to use OpenStudio and use either the SketchUp plug-ig plug-in or scripts to generate models dynamically. You can then use PAT to perturb the model using measures from the Building Component Library.
