Hi - this is something that takes a bit of knowledge and experience to assess, although there are some guidelines to help and most likely won't need much modelling other than simple back-of-the-envelope calculation. I think using OpenStudio might be a bit too much for your needs?
There are two key concepts you need to consider, with one being heating/cooling capacity (imagine horsepower for a car) which you'll pay up front and the other being operating cost (e.g. like gas/oil change etc). In HVAC, the capacity is measured in 'ton' (1 ton = 12,000 BTU = 3.5 kW). So you need to estimate how much heating & cooling capacity your house will need and compare the upfront installation cost and the operarting cost over some reasonable period (say 10~20 years).
Some food for thought:
Not sure if this helps but I've seen a lot of people get lost researching this so hopefully it's somewhat helpful...
