Having the Controller:OutdoorAir first makes sense though: the quantity of fresh air to bring in is the most important, and determines the amount of heating/cooling that is needed.
The fact that the Controller:WaterCoil for cooling coil is before the heating coil one... not sure that it has any impact. Have you tried switching the order and seeing the results?
