1 | initial version |
You can add Output:Diagnostics to show all the warnings in the err file.
!- =========== ALL OBJECTS IN CLASS: OUTPUT:DIAGNOSTICS ===========
Output:Diagnostics,
DisplayAllWarnings; !- Key 1
After running No shades.idf, you will see the following severe error message in the err file.
** Severe ** Problem in interior solar distribution calculation (CHKBKS)
** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=CUARTO_7
** ~~~ ** because one or more of vertices, such as Vertex 3 of back surface=ROOM_A1BEA5FB..FACE_75CD6136, is in front of receiving surface=ROOM_A1BEA5FB..FACE_551FD6FB
** ~~~ ** (Dot Product indicator= 0.7952)
** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead. Use Output:Diagnostics, DisplayExtraWarnings; for more details.
Please change Solar Distribution
in Building
from FullInteriorAndExteriorWithReflections
toFullExterior
or FullExteriorWithReflections
, and your simulation will complete successfully.
!- =========== ALL OBJECTS IN CLASS: BUILDING ===========
Building,
Building 1, !- Name
0, !- North Axis {deg}
City, !- Terrain
, !- Loads Convergence Tolerance Value {W}
, !- Temperature Convergence Tolerance Value {deltaC}
FullExteriorWithReflections, !- Solar Distribution
, !- Maximum Number of Warmup Days
; !- Minimum Number of Warmup Days
Please refer to the I/O Reference. It says "if the zone is not convex you should use Solar Distribution = FullExterior instead of FullInteriorAndExterior." Your model has some non-convex zones.
