Perhaps your ideal air system is doing dehumidification? See the Dehumidification Control Type input for the HVACTemplate:Zone:IdealLoadsAirSystem object. As the documentation explains, "The selected dehumidification control type is always applied when the unit is in cooling mode."
Perhaps your ideal air system is doing dehumidification? See the Dehumidification Control Type input for the HVACTemplate:Zone:IdealLoadsAirSystem HVACTemplate:Zone:IdealLoadsAirSystem object. As the documentation explains, "The selected dehumidification control type is always applied when the unit is in cooling mode."
