The ResStock documentation is out of date. If a custom buildstock.csv file is located in a project's housing_characteristics folder, it is not enough to tell buildstockbatch to use it. Instead, follow buildstockbatch's documentation for using the precomputed sampler in your project definition file: https://buildstockbatch.readthedocs.io/en/stable/samplers/precomputed.html.
You can also see an example for how to point to a custom buildstock.csv file here: https://github.com/NREL/resstock/blob/develop/test/tests_yml_files/yml_precomputed/testing_baseline.yml.
