This is a warning that is meant to remind the user to use a Controller:WaterCoil object to manage the operation of a water coil. The AirloopHVC object has an input for a controller:
AirLoopHVAC,
Typical Terminal Reheat 1, !- Name
, !- Controller List Name
This input should not be blank if a water coil is used in the air loop, and that water coil needs to be controlled IF it is not part of a system that can control the water coil. If a water coil sits on the air loop as a stand alone component, then the water coil needs a controller, otherwise a controller is not needed. So it depends on the system type whether or not a controller is needed.
This warning will not show up if these types of system are used:
COILSYSTEM:COOLING:DX
COILSYSTEM:HEATING:DX
AIRLOOPHVAC:UNITARYSYSTEM
AIRLOOPHVAC:UNITARY:FURNACE:HEATONLY
AIRLOOPHVAC:UNITARY:FURNACE:HEATCOOL
AIRLOOPHVAC:UNITARYHEATONLY
AIRLOOPHVAC:UNITARYHEATCOOL
AIRLOOPHVAC:UNITARYHEATPUMP:AIRTOAIR
AIRLOOPHVAC:UNITARYHEATPUMP:WATERTOAIR
AIRLOOPHVAC:UNITARYHEATCOOL:VAVCHANGEOVERBYPASS
AIRLOOPHVAC:UNITARYHEATPUMP:AIRTOAIR:MULTISPEED
The issue here is if you have correctly specified the necessary inputs or if the program needs to be revised to include other system types that are valid WITHOUT a water coil controller. If the simulation results show that the water coil is operating correctly, then you do not need a water coil controller and can disregard this warning. If the coil is not operating correctly, then add a water coil controller and verify correct operation.
Please advise if this warning is issued incorrectly and provide the configuration that cause this warning to inadvertently report.
AirLoopHVAC,
This input should not be blank if a water coil is used in the air loop, and that water coil needs to be controlled IF it is not part of a packaged system that can control the water coil. If a water coil sits on the air loop as a stand alone component, then the water coil needs a controller, otherwise a controller is not needed. So it depends on the system type whether or not a controller is needed.
This warning will not show up if these types of packaged system are used:
