I use these two variables (my shading control is “OnIfHighSolarOnWindows”) Surface Outside Face Incident Solar radiation Rate per Area (W/m2) Surface Window System Solar Transmitance (--) But probably in some cases if you use other shading control other variables can also be helpful
(W/m2)
