To reset, i.e. dissociate a default construction set from a story:
The "removed" default construction set will remain available e.g. for other stories or spaces in the model.
PS: You may want to edit your initial question. "I applied a construction set to a particular construction set"; I suspect you meant "I applied a construction set to a particular story".
