COMMIT_SHA and REGRESSION_BASELINE_SHA are mostly not necessary - you can set them to anything you want to, for the purposes of running the regression tests locally.
REGRESSION_SCRIPT_PATH to the folder you cloned https://github.com/NREL/EnergyPlusDevSupport intoREGRESSION_BASELINE_PATH to the build folder you compiled the 'baseline' inENABLE_REGRESSION_TESTING to TRUEmake test should run all tests including the regression comparisonsctest -j<numjobs>
