1 | initial version |
The Set Point Managers place calculated values at a node stored in a node variable. Multiple SPM's can store information on the same node. Two SPM's setting the same storage value on the same node will cause a conflict.
The temperature SPM's set Node%TempSetPoint. The dual SP temperature SPM sets Node%TempSetPoint, Node%TempSetPointLo, and Node%TempSetPointHi.
The maximum humidity SPM's set Node%HumRatMax. The minimum humidity SPM's set Node%HumRatMin.
The return air bypass flow SPM sets Node%MassFlowRateSetPoint
Setting a Node%TempSetPoint AND Node%HumRatMax variable at the outlet node of the coil (and setting TemperatureAndHumidityRatio as the control variable in the Controller:WaterCoil object when using a water coil) and choosing CoolReheat as the control type in CoilSystem:Cooling:DX object should allow humidity control.
