Hi, I suppose that you have read these instructions: https://bigladdersoftware.com/epx/docs/8-0/input-output-reference/page-090.html. You can use any text editor to create the file, paste in the following and save it in the jEPlus project folder:
eplusout.eso
eplusout.csv
Zone Operative Temperature
Makes sure that you include Zone Operative temperature as a report variable at the desired frequency in the IDF file. And, in jEPlus, select the same frequency for the RVI object. The relevant manual for jEPlus is here: https://www.jeplus.org/wiki/doku.php?id=docs:jeplus:v21:rvx#rvis_-_using_readvarseso
