Thanks you. the answer is: UA is the heat transfer coefficient. q=UA*DeltaT, so the UA is btu output of the convector or baseboard divided by the delta T in deg F across the convector or baseboard when working in English IP units.
Thanks Thank you. the answer is: UA is the heat transfer coefficient. q=UA*DeltaT, so the UA is btu output of the convector or baseboard divided by the delta T in deg F across the convector or baseboard when working in English IP units.
