1 | initial version |
absolutely. In addition, if you use a measure based solution, you could leverage the analysis capability of OS-Server and easily do a multi-objective optimization problem balancing heating and cooling loads as can be seen in the attached image.
There are some resources available in the spreadsheet link above, but feel free to ask some specific questions as well.
