See Tools > Options manager. Note that the default costs are national averages circa 2018. You cannot edit the defaults but you can make a copy and modify that, and/or you can make adjustments for inflation and local costs via Site > Screen; PV has its own separate multipliers.
See Tools > Options manager. Note that the default costs are national averages circa 2018. You cannot edit the defaults but you can make a copy and modify that, and/or you can make adjustments for inflation and local costs via Site > Screen; PV has its own separate multipliers.multipliers. See the built-in help for further details.
