In the future for a quick and easy way to model residential buildings try BEopt. It uses EnergyPlus and will create an IDF for you.
In the future for Ffor a quick and easy way to model residential buildings try BEopt. It uses EnergyPlus and will create an IDF for you.
Ffor For a quick and easy way to model residential buildings try BEopt. It uses EnergyPlus and will create an IDF for you.
