This is a good and common question! I am with the same problem.
I think you can solution it for a way more easy: dragging one definition into all the spaces with only one person. So you can use the field Multiplier to personalize the number of people to each room. I think this workflow will be add a different number of people to each space.
Can someone confirm if this worflow is correct?
