What HVAC equipment is serving the zone? Some equipment can be specified with a control type of Load or Setpoint. If the equipment is controlled by load, changing the supply flow rate/setpoint temperature won't necessarily change the space temperature if the setpoint is already satisfied. But if it's setpoint-based control, changing the supply air temperature setpoint should affect zone temperature.
