I then set the Zone Phase Change Material Melting/Freezing Enthalpy as outputs.
There is no such Outpur:Variable in Input/Output Reference although they may be select from a drop-down list in your idf file.
There is no such in Input/Output Reference although they may be select from a drop-down list in your idf file.Outpur:VariableOutput:Variable
There is no such Output:Variable in Input/Output Reference although they may be select selected from a drop-down list in your idf file.
