The data exchange between EnergyPlus and Matlba is working. Instead of using BCVTB I used the EnergyPlus Co-simulation Toolbox.
This how I defined the variable in EnergyPlus.
!- =========== ALL OBJECTS IN CLASS: OTHEREQUIPMENT ===========
OtherEquipment,
BASE-1 OthEq 1, !- Name
None, !- Fuel Type
ZN, !- Zone or ZoneList Name
Ref System work sch, !- Schedule Name
EquipmentLevel, !- Design Level Calculation Method
*, !- Design Level {W}
, !- Power per Zone Floor Area {W/m2}
, !- Power per Person {W/person}
, !- Fraction Latent
, !- Fraction Radiant
; !- Fraction Lost
!- =========== ALL OBJECTS IN CLASS: EXTERNALINTERFACE ===========
ExternalInterface,
PtolemyServer; !- Name of External Interface
!- =========== ALL OBJECTS IN CLASS: EXTERNALINTERFACE:ACTUATOR ===========
ExternalInterface:Actuator,
OtherEp, !- Name
BASE-1 OthEq 1, !- Actuated Component Unique Name
OtherEquipment, !- Actuated Component Type
Power Level, !- Actuated Component Control Type
726; !- Optional Initial Value
Output:Variable,
ZoneName, !- Key Value
Zone Air Temperature, !- Variable Name
Timestep; !- Reporting Frequency
variables.cfg File
<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE BCVTB-variables
SYSTEM "variables.dtd">
<BCVTB-variables><!--INPUT to E+-->
<variable source="Ptolemy">
<EnergyPlus actuator="OtherEp"/>
</variable><!--OUTPUT from E+-->
<variable source="EnergyPlus">
<EnergyPlus name="ZoneName" type="Zone Air Temperature"/>
</variable>
</bcvtb-variables>
OtherEquipment,
None, !- Fuel Type
; !- Fraction Lost
ExternalInterface,
OtherEp, !- Name
Output:Variable,
variables.cfg File
</variable>
</BCVTB-variables>
</bcvtb-variables>
