Look at Schedule:File objects. I'm on my mobile right now but will give a more complete answer when I get to my desk (unless someone gets there first).
Look at Schedule:File It sounds like you need Schedule:File objects. I'm on my mobile right now but will give These refer to a more complete answer when I get to my desk (unless someone gets there first). CSV file and column number which contains your input variables.
In the situation you describe though, I think you may also need to use EMS, since I'm not sure mass flow rate can be controlled by schedule directly (though there is a Pump Flow Rate Schedule Name field for the ZoneHVAC:LowTemperatureRadiant:ConstantFlow object).
