I think ZoneVentilation:WindandStackOpenArea is the best object for your use.
One thing to note is that this object has a bug when controlling window opening/closing according to the indoor temperature.
Do you have any reason you need to use Airflow network? If not, I think ZoneVentilation:WindandStackOpenArea is the best object for your use.
