Look up the overview and examples here. By default, EnergyPlus relies on a counterclockwise sequential vertex entry convention, when looking at a surface from outside its parent space/zone. A rectangular, adiabatic floor could thus be:
BuildingSurface:Detailed,
Z1:Floor, !- Base Surface Name
Floor, Slab, !- Class and Construction Name
ZONE1, !- Zone
Adiabatic,, !- Outside Boundary Condition and Target (if applicable)
NoSun, !- Solar Exposure
NoWind, !- Wind Exposure
0, !- VF to Ground
4, !- Rectangle
9.0, 9.0, 0.0,
9.0, 0.0, 0.0,
0.0, 0.0, 0.0,
0.0, 9.0, 0.0;
If such a rectangular space/zone is not fully enclosed with other surfaces (at a minimum, 4x walls + 1x ceiling), then its ceiling height & volume should be defined explicitly.
