I have a similar problem. I am trying to use the 'otherside coefficient' option just to change the temperature in front of facade for specific surfaces. Briefly, i am trying to expose the facade to two different air conditions. One surface will be exposed to outside weather conditions specified by the epw file and just another specific surface of the building will be exposed to a different temperature. I am not concerned about the radiation or wind etc other than the temperature. Is it appropriate to use the OSC option for this to set the 'other' temperature or should I use something different? Thanks in advance.
