Use a schedule like this for the Supply Air Fan Operating Mode Schedule. You can actually use any Schedule Type Limits Name that includes 0 - 1 but if you paste this into your input file and copy the name of this schedule to the Supply Air Fan Operating Mode Schedule Name field you should get the operation you are looking for.
Schedule:Compact,
SAFan_OpMode_Sch, !- Name
Fraction, !- Schedule Type Limits Name
Through: 12/31, !- Field 1
For: AllDays, !- Field 2
Until: 24:00,0.0; !- Field 3
ScheduleTypeLimits,
Fraction, !- Name
0.0, !- Lower Limit Value
1.0, !- Upper Limit Value
CONTINUOUS; !- Numeric Type
Schedule:Compact,
ScheduleTypeLimits,
Fraction, !- Name
Use a schedule like this for the PTAC Supply Air Fan Operating Mode Schedule. You can actually use any Schedule Type Limits Name that includes 0 - 1 but if you paste this into your input file and copy the name of this schedule to the Supply Air Fan Operating Mode Schedule Name field you should get the operation you are looking for.
Schedule:Compact,
ScheduleTypeLimits,
Fraction, !- Name
