1 | initial version |
My guess would be that since ventilation and infiltration are specified as volume flow rates, the difference in specific volume of the outside air at the two RH conditions affects the mass flow rate in the ventilation/infiltration terms of the zone air heat balance. You could verify this by comparing the 'Zone Infiltration Mass Flow Rate' outputs from both models.
2 | No.2 Revision |
My guess would be that since ventilation and infiltration are specified as volume flow rates, the difference in specific volume volume of the outside air at the two RH conditions affects the mass flow rate in the ventilation/infiltration terms of the zone air heat balance. You could verify this by comparing the 'Zone Infiltration Mass Flow Rate' outputs from both models.
