Zone "Atap tambahan" is indeed fully enclosed, yet its Wall and sloped Roof surfaces all have inverted vertex sequences: they're defined clockwise (when looking at them from outside the zone), e.g.:
BuildingSurface:Detailed,
F4A4D5, !- Name
Wall, !- Surface Type
Exterior Wall, !- Construction Name
Atap tambahan, !- Zone Name
Outdoors, !- Outside Boundary Condition
, !- Outside Boundary Condition Object
SunExposed, !- Sun Exposure
WindExposed, !- Wind Exposure
, !- View Factor to Ground
3, !- Number of Vertices
8.656687477963, !- Vertex 1 X-coordinate {m}
9.879976463316, !- Vertex 1 Y-coordinate {m}
4.600000000000, !- Vertex 1 Z-coordinate {m}
6.456687477963, !- Vertex 2 X-coordinate {m}
9.879976463316, !- Vertex 2 Y-coordinate {m}
3.400000000000, !- Vertex 2 Z-coordinate {m}
6.456687477963, !- Vertex 3 X-coordinate {m}
12.229976463316, !- Vertex 3 Y-coordinate {m}
3.400000000000; !- Vertex 3 Z-coordinate {m}
... they should be counter-clockwise, given the IDF's geometry rules:
GlobalGeometryRules,
UpperLeftCorner, !- Starting Vertex Position
Counterclockwise, !- Vertex Entry Direction
Relative; !- Coordinate System
Incidentally, the 2x sloped Roof surfaces (like "F4A4D5" above) are labelled as Walls. That likely triggers the 90.1 surface tilt warning.
